Quick Help! Power Steering Pulley Remover
Im gonna be pulling my tranny and motor tomorrow and Im trying to figure out what I need or if I do need a special pulley remover for the power steering pump pulley. Do I need a special one or will I be able to find one at any parts store? Thanks!
I left my pump attached to the bracket and wired it to the side when I took my engine out. You do need a puller/installer and it is available for rent or sale at Autozone or Advance Auto Parts.
Dave
Dave
I've pulled the power steering / alternator bracket off the motor and layed it to the side and pulled the motor before, no need to pull the pump, pulley or disconnect the lines. The alternator even stayed in the bracket, just disconnect the wires and lay the bracket down near the a/c coil (radiator removed). This saves you alot of trouble.
lxcoupe
07-08-2015 05:49 AM
