RCSB available w/ LQ9 for 2006
Old 08-03-2005, 11:37 AM
MOOBIES Moderator
Scream's Avatar
Default RCSB available w/ LQ9 for 2006
Watch out Ford and Dodge! It's officially on GM's website! WOOOHOO!
http://media.gm.com/us/chevrolet/en/...ndex%20LD.html
Old 08-03-2005, 11:45 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Damn thats pretty sweet if I read the charts correctly you can get a 5.3 with a manual.
Old 08-03-2005, 11:48 AM
Kano's Avatar
its about time
wish I'd had this option back in 03
good find scream
Old 08-03-2005, 11:52 AM
MOOBIES Moderator
Scream's Avatar
No, if you read the fine print the 5.3 is still only available w/ the 4L60E. But the good news is that you can get a RCSB w/ the HO 6.0 AND the 9.5" rear end. So we'll also finally have an easy option to use the 9.5" rear in our trucks! This is VERY exciting!
Old 08-03-2005, 11:55 AM
MOOBIES Moderator
Scream's Avatar
VortecMAX Performance Package:
Designed to enhance the towing capability of 4WD models of the Silverado 1500 extended cab/regular-length box and Silverado 1500 Crew Cab, the new VortecMax Performance Pack includes a high-output Vortec 6000 engine rated at 345 horsepower (257 kw) and 380 lb.-ft. of torque (515 Nm), a heavy-duty trailering package and a new 9.5-inch rear axle.
The high-output 6.0L engine and heavy-duty 9.5-inch axle help give Silverado best-in-class towing capability. The VortecMAX Performance Package also includes a locking rear differential, special exterior badging and a unique engine cover.
The VortecMAX Performance Package is available on all 1500, 1500HD and 2500HD cabs, with either 2WD or 4WD. It is available on vehicles with mid- and uplevel trim.
Old 08-03-2005, 12:00 PM
TXsilverado's Avatar
man, i do all this work to make my truck semi quick and now you can buy them from the factory to kick my *** i want one
Old 08-03-2005, 12:05 PM
MOOBIES Moderator
Scream's Avatar
Dangit...it's only available on the Chevys. Why not the GMCs?!?!?!
http://media.gm.com/us/gmc/en/produc...ndex%20LD.html
Old 08-03-2005, 12:30 PM
white1's Avatar
Bout damn time
Old 08-03-2005, 01:09 PM
MOOBIES Moderator
Scream's Avatar
I got all giddy for a second, but this has to be a misprint...
The Silverado SS is based on the 1500 Series Extended Cab with a short bed. It is powered by a high-output version of GM’s Vortec 6000 V-8, which pumps out 345 horsepower (257 kw) and 380 lb.-ft. (515 Nm) of torque. The engine is connected to a Hydra-Matic 4L85-E four-speed automatic overdrive transmission equipped with a 3.06 first gear and 0.70 final gear, which transfers power to a 4.10-geared locking rear axle for rapid acceleration and relaxed highway cruising.
The 4L85E in the SS? It's listed that way in two different spots, but the gear ratios are that of the 65-e. Hmm, a 1/2 ton w/ the 85-e?!!?!?
Old 08-03-2005, 04:40 PM
Sleepy53's Avatar
That would be awesome if the 6.0 was available for RCSB in 06. Wish it was sooner!
Quick Reply: RCSB available w/ LQ9 for 2006
