The real results from camming
ok let me explain this in a nice way.
I don't know how anyone feels torque, what you really feel is horsepower, anyone notice the vehicle accelerates faster at a higher rpm even with less torque?
Torque is the measure of the engines output in ONE revolution, while horsepower measures the engine output from one rev multiplied by the number of revs.
So while your engine is making big torque at 3500rpms, and making much less torque at 7000rpms, the rate of increase in RPM is greater than the rate of decline of torque which means you make MORE power.
F1 engines, bike engines, high revving engines in general make very little torque, but are able to carry that torque over a very large rev range which is why they make a lot of power, an F1 engine makes 202lb-ft of torque at 18,000rpms, which means its making 730 hp at that range.
A good cam will shift your torque curve UP, and to the right, and reduce how fast torque drops after peak torque, all those put together make for much more average horsepower throughout the range.
One analogy I heard before is that horsepower is how fast you hit the wall, and torque is how much of the wall you take with you after you hit it.
The way I perceive it is that an engine makes torque. Once the engines starts spinning it makes horsepower. Horsepower is the rate at which the engine produces torque.
Just my 2 cents.
Just my 2 cents.
The real effect of camming is more torque from my perspective i can only see gaining more torque because these ls motors generally max out the same im mph
so im only really gaining torque
if im going to shell out 700 bucks for a cam,springs, push rods, etc supplies im paying for torque is this true ?
I love torque dont get me wrong
HP = (Torque x RPM) / 5252
Torque does all the work and horsepower is nothing more than a way of measuring an engines ability to produce torque at any given rpm. Obviously this means that any time you gain torque at an rpm you will also increase the hp at that rpm.
