Replace Parking Brake Shoes?
Ever since I bought my truck used the parking brake hasn't worked. It goes all the way to the floor and doesn't hold the truck in place at all. The adjustment nut on the drivers side under the cab is all the way tight. Does this mean the parking brake shoes are completely worn down, or is there another point of adjustment?
Thanks!
Thanks!
mine has been doing the same thing. i had it all apart and my pads didnt look all that bad to me. only the very tips looked bad. but the other 75% looked good
sorry i know thats no help but im also wanting to know whats wrong. i can use the adjust nut until its so tight that i can only put it half way down as hard as i can and it still doesnt do anything. i think my cable is stretching out or something. any help would be great thanks!
i tried that when i did had everything apart doing the drop. may take everything apart again next weekend give it a good once over and see if i can find anything wrong.
11 Second Hall Moniter
It's not uncommon to see those park brake shoes fall loose out of their clips, and wear out. Sometimes they are metal to metal, even though the parking brake rarely gets used. The best thing you could do is remove both of the rotors and see what's going on in there. It may be a simple adjustment, or they may need replaced. Only one way to find out.
Ive seen quite a few have the friction material come unbonded from the actual shoe. I tip also is when replacing them I never take the screw out of tge retaining clip. You can just pop the shoe out of the clip then walk it around the axle flange. Took me a few broken screws to learn than, theyre prone to breaking off.
dry_kill
11
08-28-2015 09:53 PM
atxlt
07-20-2015 11:06 PM
