replaced fuel pump and now the truck doesnt want to idle
Old 05-03-2009 | 06:37 AM
wkdivr's Avatar
There is no inline filter on the 04 and up trucks. Only the sock on the pump, for some odd reason. I don't think it would be a good idea to put one inline, either, because the regulator is in the pump module. It would restrict too much flow.
Old 05-03-2009 | 01:30 PM
05cc's Avatar
Originally Posted by Spoolin
I had the same problem last week when I swapped TB's. I disconnected the battery and had to let the truck relearn itself. After that it was all hunky dorey! I also swapped the fuel pump on a friends truck 2 days ago...two of us had trouble getting the bed off by ourselves...you do it on your own? how'd you do it?
yea i did it all on my own. i just used my shop forklift w/ tie downs attached to the 4 corners.
so what i'm understanding is, when i put the new pump in, the new fuel filter was already attached to that, am i right? or is it completely separate from the fuel pump and still in the tank somewhere else? i'm still getting that hesitation but its not occurring as much or as strong. i guess i should probably move on from the fuel pump and filter, to some of the things that 1FastBrick mentioned.
Try cleaining the Throttle body opening, the Blade, IAC Valve and its passage, and also the mass Air flow sensor.... BTW if you haven't done it a fuel filter is also recomended.
FWIW IAC Valve is short for Idle Air Control Valve
about 4 weeks ago, i seafoamed my truck. i poured it down the brake booster line, and while it was soaking i sprayed the seafoam deepcreep into the throttle body opening. the truck ran good before the the seafoam and even a little smoother after the seafoam. so i hope this hesitation isnt from me seafaoming and causing something to clog up.
Old 05-04-2009 | 10:55 PM
05cc's Avatar
so i wanted to make sure the MAFS was clean and wasnt causing the problem and i think i found the culprit.
Old 05-05-2009 | 05:53 PM
shandy294's Avatar
Isn't the IAC different,too, on a truck that new? I know my 04 is different in a lot of ways from a friend's 2000 5.3 . Maybe after you clean the TB it'll get better.
Old 05-05-2009 | 09:22 PM
05cc's Avatar
it wasnt the TB that was causing the problem, it was the huge crack in the rubber right after the MASF. i cant seem to find anything to replace it. all the checker and autozones only have that cupler for little riceburners. i need one w/ an ID of atleast 3.5".
Old 05-05-2009 | 09:54 PM
1FastBrick's Avatar
Custm2500's Rude Friend
well son of monkeys uncle... There you go...
I guess it will either be an ebay part or contact the company that makes that kit...
if not, maybe a local parts place can order it and have it withen a day or two....
5.3lSilverado
25
08-29-2016 12:48 AM
ullose272
08-05-2016 02:05 PM
GMCtrk
07-17-2015 06:39 PM
black6spdz
07-16-2015 01:32 AM
GRRR65GTO
07-10-2015 08:27 PM
Quick Reply: replaced fuel pump and now the truck doesnt want to idle
