resistor for airbag delete
Old 06-06-2006, 02:17 PM
jephs422's Avatar
Default resistor for airbag delete
I removed both of my airbags on my 2000 RCSB and I figured if I leave the module hooked up, and put a resistor in line where the airbags were, I should be able to eliminate a light, right? If so, does anyone know the correct ohms, or possibly another way to avoid a light.
Old 06-06-2006, 03:07 PM
LS1Tech Whore
Dirty 30's Avatar
Same question here. Also noticed there are wires hooked up to the seats on mine that control the automatic pass side airbag.
Old 06-06-2006, 03:17 PM
Yelo's Avatar
test the airbag using a NON-CURRENT-INDUCING ohm-meter (an analog meter is usually safe....avoid a digital meter as it may make the airbag detonate ) to see what the airbag's actual resistance is, then go buy a resistor of the value (+/- 10% is OK)
Old 06-06-2006, 07:34 PM
03NHSilvy's Avatar
Why did you choose to pull the airbags?
Old 06-06-2006, 08:09 PM
LS1Tech Whore
Dirty 30's Avatar
I want to get a diff. steering wheel
Old 06-06-2006, 08:18 PM
jephs422's Avatar
weight reduction.
Old 06-06-2006, 09:14 PM
High on diesel fumes
thunder550's Avatar
Originally Posted by jephs422
weight reduction.
Hmmm....could this be where Brian's abandoned race truck project ended up??
Old 06-06-2006, 09:55 PM
jephs422's Avatar
Old 06-06-2006, 09:57 PM
blownerator
BlownChevy's Avatar
if you are looking to save weight....just pull the bulb stupid.
Old 06-06-2006, 10:01 PM
jephs422's Avatar
well I could do that, but I would rather come up with an extremely complicated solution involving numerous devices that could both injure me and or destroy my truck. Only then will I be fully satisfied in knowing the problem is fixed.
Or you could just pull the bulb for me ***...
Quick Reply: resistor for airbag delete
