Screwed
Screwed
Ok this is the skinny pulled stock headers off 2007 Tahoe and one broken header bolt, that's problem one any ideas to fix it's actually inside the block a little too. Second I ordered some pacesetter headers with Y pipe from Texas -Speed great guys hooked me up. Parts show up I called them twice to double check on part numbers, wrong headers car in pieces need help asap.
Now that is the problem it's a 4x4 so i'm see if Texas-speed will man up and send the right ones and I can just toss them in since all the hard work is done
I've done quite a bit of business with Texas Speed, and have worked on Charity Events with them. I have never had an issue with them.
11 sec. Truck Mod
OP, get it straightened out with Texas Speed and let us know how it turns out.
As for your broken manifold bolt, your gonna have to see if there is any way you can grab the bolt with some channel locks to try and get it out, or you will have to drill it out and re tap the hole. Good luck.
get a good extractor set. reverse bits and extractors. works wonders, and theyre nice to have around when you need them.
also there are two sides to every story. It could have been he accidentally ordered the wrong headers, or they accidentally shipped the wrong ones. No one really needs to "man up". when there is an issue like this, just call and have an intelligent conversation with them and chances are they'll get you the right parts. manners go a long way
OP, not directed to you, just saying, in general.
He's not giving them an opportunity to make resolve with the issue. And it's got nothing to do about manning-up, it's about doing good business. **** happens, no one's perfect. Though we'd like to think so...
I understand the harsh words but the main problem I had was i checked and double checked before I ordered them over the phone and they are a great company and were very helpful. At the same time as soon as the headers showed up I called them and double checked two more times cause the part number is for a 99/06 tahoe and I have a 2007 and they are different, I was told all set so I finally got home from training in military to do this now the truck is in pieces and I'm kinda screwed. I just really hope they can send me the right stuff ASAP and I would even pay to ship the others back just wanna get this fixed asap I leave again this Friday sooo. Appreciate the feedback though and as of now no problems with Texas-Speed, just hope they can fix this asap.
To add to this. I build up the weld to get a little nub showing, then I weld a nut onto the nub. I let the weld cool for a minute or so and then back it out with a socket and ratchet. It takes longer to get the welder out than the bolt.
GM1697
09-09-2015 01:52 PM
smokeshow
08-23-2015 08:23 PM
