Scsb mild build 6.0 running a 16.8 WTF?
Old 08-20-2011 | 07:31 PM
  #21
dlt76028's Avatar
Originally Posted by silverado2000
well i went and drove it around with with a scanner hooked up no codes or anything everything seemed good. i got 0 KR the whole time but my timing only went to 22 at wot, is that normal?(threw the all the rpms there was no curve to it 22 from 2500-6400) seems low to me but im no tuner.
Originally Posted by Suburbazine
That's wrong. You should range from 15-20 to 45ish. If you're locked at 22 you should find out why. Have your tuner check your spark advance tables for interfering factors.
Yea are you saying while just driving under part throttle, timing never went above 22? Part throttle should go alot higher. Now 22 wot isn't that low, my old 6.0 ran best at 25 wot. Anyway you look at it, it should at least be in the 13's
Old 08-20-2011 | 09:35 PM
  #22
silverado2000's Avatar
Wot 22, cruising it would be in the 30's
Old 08-20-2011 | 10:45 PM
  #23
tarinitup's Avatar
9 Second Truck Club
Throwing more timing at it isn't the fix. A 6.0 rcsb running 16.8 has something mechanical wrong but it's just easy to blame the tune. I had a similar experience and got 6 retunes but stayed the same until I opened the valve covers and saw loose rocker. Running on 7 cylinders kills performance. Btw lost 2 sec off quarter with that.
Old 08-20-2011 | 10:49 PM
  #24
I'm not blaming the tune, 5 retuned show it's mechanical. During the cam swap I'm checking all the valvetrain.
Old 08-20-2011 | 11:57 PM
  #25
skolman91's Avatar
Lets get a dot 2 dot cam timing pic while your swapping cams..?? Or even a pic of before you take it apart..?
Old 08-21-2011 | 12:09 AM
  #26
skeet's Avatar
good compression and leak down test might help ya also to determine the issue
Old 08-21-2011 | 12:12 AM
  #27
I'm going to get a few pics of the dot to dot, and the timing chain. when I find the prob I will let y'all know no worries there.
Old 08-21-2011 | 07:01 AM
  #28
stock48's Avatar
9 Second Truck Club
new plug wires did the gto wires, coils are good i have swapped them with known good set. i unplugged each injector as the truck was running and each made a miss, and i have pulled them and cleaned them. do you mean a torque converter? yeah it has a yank 3600...
stock48 is there anyway besides changing the lifters to check for lifter pump up?
When the lifter is on the base circle of the cam the pushrod will stick up higher than the rest. You have to pull the rockers off and measure all intake, and exh. Be sure the lifter is pushed down on the base circle of the cam. That #8 plug doesn't look right. Just because a injector is firing doesn't mean it's always good.
Old 08-21-2011 | 01:23 PM
  #29
started the cam swap about an hour ago, just waiting on the crank pulley puller then ill have some pics of the dot to dot and all that.
Old 08-21-2011 | 05:14 PM
  #30
heres a few pics of the dot to dot, looked perfect to me. all the rocker arms were tight and moved properly.
Attached Thumbnails Scsb mild build 6.0 running a 16.8 WTF?-photo-74-.jpg   Scsb mild build 6.0 running a 16.8 WTF?-photo-75-.jpg
Quick Reply: Scsb mild build 6.0 running a 16.8 WTF?
