Seafoam'd my 118k truck and barely any smoke
Old 03-10-2011, 10:35 PM
charcoal03silvy's Avatar
Truck feels a little slower today to me after i changed the oil and seafoamed it.
Old 03-11-2011, 09:48 AM
TXsilverado's Avatar
I've seafoamed many different vehicles, always used the same method, and it seems to be hit or miss as to whether they smoke or not. It seems that the Seafoam alone would cause a ton of smoke, but not always. Weird.
my theory is the smoke is actual carbon build up. ive foamed the same vehicle 2x in a row using the same method. smoked like a train the first time, and barely at all the 2nd time.
Old 03-11-2011, 11:04 AM
chevyboy.520's Avatar
When you guys add the sea foam, you guys add it, by pouring it into the brake booster line? Which goes straight into the intake manifold? Then in threw the heads and out threw the exhaust?
Old 03-11-2011, 12:45 PM
yep. let the brake booster suck it up.
Old 04-21-2011, 12:20 AM
jeffz0rz's Avatar
im going to have to get some seafoam. ive got 120K and its never been done. i just cleaned the tb and it was really bad. my truck runs fine, completely stock besides my diablo sport, you think my truck will run better after the seafoam? not looking for a performance gain, i just want a smooth running engine.
Old 04-21-2011, 05:37 AM
Coban's Avatar
I've never understood, how does this not hydro-lock the engine? Does is vaporize, or do you just have to watch the volume you put in?
Old 04-21-2011, 06:56 AM
stone150's Avatar
I have always been a little suspicious that it would screw something else up.
Old 04-21-2011, 07:15 AM
6789olds's Avatar
i did my blazer once and let it sit for 20 min and got no smoke . but the second time i did it i only let it sit for 5 min and it smoked like crazy .
Old 04-21-2011, 08:36 AM
Sc00by's Avatar
I did mine a few months ago. 230,000 miles and had never done it. I pulled the vacum line off of the brake booster and stuck that in the can. You need to have the engine at operating temperature and feed it fast enough that the engine is a little hesitent to stay running. The key is RIGHT AFTER the can is gone shut the engine off for about 5 minutes. Dont try to rev it up before you shut off......just shut it off. It MAY take a few seconds longer to crank it up as it is pretty much flooded. And it WILL run like crap....there is a good chance you will have to feather the throttle to keep it running. Bring your RPM's to around 2000-2500 and run it till it stops making the thick white smoke. Then drive as normal. Mine still smoked for a few miles of driving AFTER it stopped creating the thick white cloud. This is pretty normal.....you didn't blow or mess anything up....its just burning the rest off that may have pooled.
My truck has NEVER ran so good after this was performed.
Old 04-21-2011, 10:00 AM
Randy 5.3's Avatar
Still havent got the guts to seafoam my truck. Scared ill mess something up!!!!! Been wanting to do if for some time though.
Quick Reply: Seafoam'd my 118k truck and barely any smoke
