Service 4 wheel light
I got the ground
...why don't you simply add a ground (from the frame) to the connector, just to get it working? That's pretty easy.
Then figure out why the ground is missing.
My 04 Suburban had the entire bundle of wire severed. Like if was somehow stuck on the front driveshaft somehow. I respliced the harness, and my "service 4wd" message was still there and it was still stuck in 2wd. It would up being the little reluctor wheel inside the encoder motor. I think it's called range something it's $20.
Here's the thread I made. Post #11 has the parts I was talking about and how I tested mine. Maybe that's your problem?
I hope this helps: https://www.performancetrucks.net/fo...essage-560255/
The black wire goes to pin A of the control module, labelled "CW" on the schematic. It only gets grounded when the control module grounds it. Which is, when it is commanding the motor to spin in one direction. It ends up going to battery when the module is commanding the motor to spin the other direction, at which time the red wire, which goes to pin B of the module labelled "CCW", gets grounded.
Which is probably why the motor now goes all the way one way and can't come back the other way... the module can no longer reverse the voltage on those wires like it's supposed to.
Pin C of the module goes to ground. Pin D gets 12V from the ATC fuse.
The black wire DOES NOT belong going straight to ground.
GM1697
04-21-2016 09:06 PM
