Silverado instrument cluster
Has anyone bought the silverado instrument cluster with transmission temperature gauge? How much was it?
Do I conclude correctly that the sensor is there because the message center will light up a message of trans hot as necessary?
Is it a matter of just changing the cluster and inputing the mileage?
you can find them at www.car-parts.com just search under a 2500 with a 6.0 or 8.1. should be around 100.or try ebay
PT's Slowest Truck
99's require some sort of modification to make clusters from other years work. I think that if you just swap in a cluster from a different year you get an air bag light or something like that. I got my Denali cluster from JP Customs for $275, it comes already modified so it's just plug and play. If you check their website you'll notice that there's a different part# for the 99's as opposed to other years.
Originally Posted by fogle04
you can put a tranny guage in your stock cluster. there was a write up on it a little while back. try searching for tranny temp guage install
Offroadunleashed
07-20-2015 02:25 PM
350SS
07-11-2015 12:34 PM
