single cab awd??
Old 11-26-2008 | 11:17 PM
02gmcbandit's Avatar
Default single cab awd??
has anyone ever did a singlecab awd on here??
jus a thought that went through my head today on the way home while geting my @$$ handed to me be a ss
Old 11-26-2008 | 11:19 PM
viciousknid's Avatar
Where's the Beef?
It's better with 4wd than Awd cuz you have the option.
If your starting off with a 2wd and you want to make it awd or 4wd you have to swap frames.
Old 11-27-2008 | 12:32 PM
L7 Sierra's Avatar
Buy the 4wd with the upgraded auto track transfer case.
I has this idea myself since when you put it into 4wd high it acts just like the AWD system the SS uses.
Since I live in Southern California I don't have inclemate weather to deal with so I got a 2wd, but if you live up north it could be a nice saftey feature so you can tell your wifey that.
Old 11-29-2008 | 12:41 PM
BobbyBa's Avatar
Can you use the Denali frame,drivetrain and put a 2000 Silvera.do stepside body on it.
I know the wheelbase is different. What else would be involved?
Old 11-29-2008 | 01:47 PM
Bo185's Avatar
In 4 high it does have the viscous-coupled transfer case and you'll wind up braking something if you try to drive normally in 4high especially while turning.
You could swap in a NVG 149 from an SS.
Old 11-29-2008 | 01:56 PM
so i could take a single cab 4wd, slam int, change out transfer cases to one out of a SS and itd be the same differance as haveing a singlecab awd?
Old 11-29-2008 | 02:12 PM
RandomHero's Avatar
Basically yes, but why would you want to? AWD doesn't really offer anything better than 4wd and with 4wd you can save yourself a few mpg and run it in 2wd most of the time.
Old 11-29-2008 | 04:47 PM
Wyttrash96's Avatar
I hate my cats
To answer your question, Wide Open did it, with a drivetrain from a new Escalade or Denali or something. It sounded like a monster, but I don't think there was ever a video, don't think he has the truck in the same configuration right now, and I don't think he's on here that much anymore.
323steel36
08-25-2015 06:11 PM
SSmoothSilSS
08-23-2015 02:54 PM
1bad2k
08-18-2015 10:50 PM
Aboss
07-09-2015 11:28 AM
