small clunk sometimes when i hit the gas
Old 12-01-2010, 05:57 PM
40series's Avatar
Default small clunk sometimes when i hit the gas
clunk happens sometimes when i hit the gas? from under ther truck sometimes its from the rear some times its forward like in the middle of the drive shaft
Old 12-01-2010, 06:13 PM
13 Second Truck Club
DV2000NJ's Avatar
More than likely it's the slip-yoke. Do a search on here, I'm sure it's been covered time and time again.
Old 12-01-2010, 07:26 PM
Where's the Beef?
viciousknid's Avatar
or ujoints`
Old 12-01-2010, 08:31 PM
iamkeniff's Avatar
^^ agree OR that slip yoke is dry...need to grease it (if its an escb) *the rear shaft is what im talking about* ive seen a couple have a clunking noise where its dry and when you put it in gear it forces it to move
Old 12-01-2010, 08:45 PM
quicksilverado's Avatar
Put some grease in the slip yoke and that will solve the problem.
Old 12-02-2010, 06:57 AM
It's the rear slip yoke, trust me. GM re-designed a new one to fix that proble but it's astronomically high, like $150. But it does work. The OEM design is notorious for the clunk that you hear. You can barely throttle the gas and it will "clunk" everytime.
Old 12-12-2010, 08:07 AM
Len
Registered User
Len's Avatar
2000 silverado lacks power, put new fuel pump in and a new transmission and plugs , still runs bad no power
Old 12-12-2010, 08:48 PM
14 Second Truck Club
double047's Avatar
Mine is doing this also, and I have filled the slip yoke with grease twice.
Old 12-12-2010, 10:09 PM
PT's Slowest Truck
budhayes3's Avatar
The nickel plated slip yoke cured my clunk...installed it when I swapped my trans this past May
Old 12-27-2010, 01:51 PM
aeorozco's Avatar
I have a chunking noise in my avalanche so i replaced the u joints in it about 2 weeks ago, still hear it..... not as bad but its still there - Thought my tranny might have been low so I checked and its right on the money, rear diff was low, not really sure exactly how low but I was able to put in a little last bit of gear oil i had at the house. I can also feel vibrations in my steering wheel but I think that this may be due to a front end wreck and may be in the steering gearbox, almost sounds like its loose. sounds like i have to add this to my list of to -do's
Quick Reply: small clunk sometimes when i hit the gas
