So Ize been thinking, reverse rotation BBC set up, hmmm
Baltimore Whore
![Cool](https://www.performancetrucks.net/forums/images/icons/icon6.gif)
I am pretty twisted some times, get to thinking. We happen to have a 502 that is in pieces. It was a marine engine, is also reverse rotation. I do know they make a few hot rod cam grinds for a reverse rotation engine. So with that being said, I know it would be alot of work, but I could use a 2 speed velvet drive marine transmission. It would need the adaption of a bell housing, along with a clutch revision, but could def be done. Alot of old school racers were adapting clutches to 350-400 turbo tranys, with excellent results. Again, just a thought. It would be so bad *** and a WTF factor if you seen a vehicle pull a right front tire, instead of the left, noo?
Baltimore Whore
Velvet drives will return the drive shaft to a normal/standard rotation, through a internal gear . Not sure how much that affects the way the thing would pull.
Why can I not have endless amounts of money. I would spend it on doing cool ****.
![hmm](https://www.performancetrucks.net/forums/images/smilies/hmm.gif)
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
