spark gap on 5.3 is it .060 or .040?
Old 09-19-2009, 08:50 AM
12 Second Club
Slp2002Z28's Avatar
Default spark gap on 5.3 is it .060 or .040?
whats the correct gap for the spark plugs..05 gmc 5.3??
Old 09-19-2009, 09:33 AM
03 BLACKOUTSSS's Avatar
I believe they are factory platinums, so I think it should be .040"
Old 09-19-2009, 03:16 PM
12 Second Club
Slp2002Z28's Avatar
I put ngk tr 55 gap-out the box
Old 09-19-2009, 03:34 PM
Where's the Beef?
viciousknid's Avatar
i think it depends on the plug.
what kind is it?
Old 09-19-2009, 05:09 PM
skolman91's Avatar
i just did mine recently and checked them outta the box and they were all around .055 so i didnt mess with them. imo i wouldnt go under .045
Old 09-19-2009, 07:38 PM
terravast4's Avatar
specs call for 2004 and up .040 gap
Old 09-19-2009, 07:51 PM
PT's Slowest Truck
budhayes3's Avatar
That's the factory gap for an iridium plug. If running copper or platinum, they will work best gapped around .055-.060
Old 09-19-2009, 08:05 PM
Resident Retard
BlackGMC's Avatar
That is what i just gapped mine at when i recently replaced them...
For the experiences on my 04, i don't agreee with that...
I have tried tr55s gapped at .60, .55, and .4.. The .4 idled the best but not as well as the iradiums.....
on the Iradiums i just put in they idled best at .4...
Old 09-19-2009, 08:24 PM
PT's Slowest Truck
budhayes3's Avatar
That's interesting, you should *generally* idle smoother with the wider gap I believe. Iridiums pretty much have tighter gaps than copper or platinum, there's a precise reason for this which I used to know when I spent a lot of time researching spark plugs, but I'm drawing a mental block on it right now for some reason. My truck came factory with platinum plugs and the spec is .060, but fwiw, when I removed my plugs the gaps were inconsistent and ranging from .045 to .065, and the truck ran fine. I swapped in some pre-gapped Denso Iridiums, and then tried some NGK TR55's gapped at .055, and haven't noticed any idle differences, and I'm pretty keen to how my truck runs. Although, there may be differences in the tune from an 04+...I think someone (might have been you actually?) posted up slight spark dwell differences.
Old 09-19-2009, 08:27 PM
GMCtrk's Avatar
I run tr55s @ .055". Works fine.
Quick Reply: spark gap on 5.3 is it .060 or .040?
