spark gap on 5.3 is it .060 or .040?
Old 09-19-2009, 08:42 PM
Resident Retard
BlackGMC's Avatar
Although, there may be differences in the tune from an 04+...I think someone (might have been you actually?) posted up slight spark dwell differences.
Yep it was mean that posted the differences in the tunes
Also your setup is ALOT tamer than mine.... My cam's overlap and 9.5 converter has ALOT of idling issues... Very small changes can affect my idle alot more than yours...
Anyways, i was simply stating my experiences, seems like most gap them at .55 and they run fine, however mine didn't
Old 09-20-2009, 06:44 AM
PT's Slowest Truck
budhayes3's Avatar
All true Corey...honestly, I guess that the correct gap depends on the hard parts combined with the tune. The first time that I swapped plugs I think I was mostly stock with bolt ons....I was quite surprised to see how inconsistent that the gaps were and how clean the plugs came out.
Old 09-21-2009, 11:58 AM
OEM reccomended and set gap is .40
Old 09-22-2009, 11:09 AM
ap2002's Avatar
I have always ran TR6's, 110lsa cam, and converter, truck idles perfect, zero issues, do yall think its better for me to swap to TR55?
Old 09-22-2009, 11:24 AM
SILVERBIRCH's Avatar
I did tr55 iridium plugs when i did my cam swap and left the gap alone i am not sure to what gap they are at but it idles fine.
I also heard that it is not good to gap tr55i because the tips can break easily.
Old 09-22-2009, 11:38 AM
PT's Slowest Truck
budhayes3's Avatar
This is true, the iridium tip is micro-welded on and can't be pried against or it will snap off. If gapping is necessary for whatever reason, needle nose pliers or something is needed to grab the ground.
Old 04-06-2021, 07:16 PM
Registered User
Michelle Gilbertson's Avatar
Default No power
Does anyone know why I have no power ,I replaced throttle body sender new plugs ,new mass air flow,reset computer did the grounds sti it's sluggish????
Old 04-06-2021, 08:34 PM
terravast4's Avatar
this spark plug gap thread is 12 years old.
skyhighsami
08-12-2017 08:42 PM
outlaw38
10-05-2011 03:33 PM
blklime02
14
12-25-2008 12:03 PM
Black-Syde
14
09-06-2005 10:46 PM
JimS
08-12-2005 10:07 AM
Quick Reply: spark gap on 5.3 is it .060 or .040?
