Spark plug suggestion
Old 05-19-2010, 09:00 AM
Wearin' da big hat
00ChevyScott's Avatar
$2.49 a plug for the NGK TR55 Coppers
Old 05-19-2010, 12:22 PM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by BLUES MAN
you want the gap to be .040
.040 for the iridium plugs, .055 to .060 for the coppers...
Old 05-19-2010, 03:03 PM
The House is Rockin'
BLUES MAN's Avatar
damn! i get my coppers for $1.64
Old 05-19-2010, 03:10 PM
Wearin' da big hat
Idk what I pay with my employee discount, but ya those NGK V Power plugs have gone up in price a little bit.
Old 05-19-2010, 03:14 PM
BLUES MAN's Avatar
i thought they were supposed to be .040 for the coppers too?
Old 05-19-2010, 03:26 PM
Wearin' da big hat
It used to be .060" for the original AcDelco plugs, but they changed the design and all the new plugs and all aftermarket plugs are supposed to be set at .040" now.
And according to my NGK book, 07+ is actually .044" gap.
Old 05-19-2010, 05:01 PM
Budman52tx's Avatar
thanks for everyones help i am going with the ngk iridiums.....and getting a nelson tune
Old 05-20-2010, 12:09 PM
PT's Slowest Truck
budhayes3's Avatar
Don't look at the listed specs when changing out the original equipment to something different, the different metals require different gaps...if the truck came with iridium plugs and you change them out for a copper plug, you've just changed the resistance in the secondary ignition system, and theoretically could wear the plugs faster, burn out a coil, or cause other problems (that probably won't happen, but "theoretically" could). the truck will run fine with the smaller gap on a copper plug, but will be most efficient with the larger gaps. If you want to run the smaller gap, run the iridium plug that the gap was intended for, but if you're switching out the OE parts for something that it wasn't designed for, you have to make adjustments to compensate...make sense? The spark dwell has been changed in the tune for the iridium plugs also, and changing the metal of the conductor will have an affect on the way that works when the spark jumps the gap.
BTW, I'm currently running NGK TR55's gapped at .055, but have a set of NGK TR55ix's that will be going in when these wear out or when I swap in my LQ9, which ever comes first...those NGK's will be gapped at .040 which is where I believe they are pre-gapped to.
Old 05-20-2010, 12:35 PM
BLUES MAN's Avatar
well that def cleared up any questions i had. thanks billy!
Old 05-20-2010, 12:55 PM
PT's Slowest Truck
budhayes3's Avatar
You're very welcome
Quick Reply: Spark plug suggestion
