View Poll Results: Which Staggered rear size?
275/55/20
0%
285/50/20
0%
295/45/20
100.00%
Voters: 15. You may not vote on this poll
Staggered poll
Staggered poll
Due to abnormal tire wear from my alignment being out for a while I need to replace a tire. Rather than replacing just 1 i'm going to replace 2 and am leaning toward going with a staggered fitment.
I currently run 275/45/20 and am not sure what other 2 to buy.
In Hankook ventus RH06 (which i want) I can get 275/55/20, 295/45/20, or 285/50/20
I want 295/50 but don't see anyone that has them. Do you think I should do 295/45 or go 1/2 way and grab the 285/50/20's for rear so I have a bit more mph out of each gear over what I have now with my 4.30 ratio?
go as wide as possible if you dont it will barely show any difference. That being said, 295's all the way. And like MC's you'll probly go through a set of rears before you will need a set of fronts. Good and bad, but I didnt even need a second set of rears when I needed fronts
It's only lowered 2" in the rear.
295/45 is 30.45" and 285/50 is 31.22"
I have some 265/70/17's I run on occasion which is 31.61" so it would be Awesome if I could find some 295/50's which are also 31.61 so I don't have to recalibrate my speedometer when I switch.
I guess I'm gonna go for 295's and do some more searching to see if I can get it in a 50. If not I'll get it in the 45.
Thanks
Thanks
gcsd3742
07-06-2015 05:22 PM
