Steering shaft rattle/clunk revisited. Not your typical clunk thread. Good info here
I just finished replaced the bearing. The good news: it's very easy to do. The bad news: it didn't help me one damn bit. Groan is still there, really bad when turning to the left, does it a little when turning to the right.
Tried reaching through the window to turn the wheel while standing outside and the sound does seem to be coming from pump/box area. I need to draft someone to turn the wheel for me so I can listen closer though.
This sucks. Time to start reading some bulletins and see how much this is gonna cost me...
Well doing some more investigation on my problem I don't think that bearing is it. While it probably could stand to be replaced my problem is really noisy fluid flow in the PS system. I think this is also a common problem. I hope to verify this with a GM tech and I fear that I need a new steering gearbox to fix the problem. The noise and vibration is very load and apparent near my steering gearbox.
2004 silverado steering tube bushing
I want to thank the contributor of the info and pictures pertaining to this. I had already taken my truck to my frontend guy and got the intermediate shaft replaced. But, I still had some of the rattle still hangin on. I saw the post on here, went straight to chevy parts, and fixed it, all because of info I got here. Now...on to the noisy passenger side door panel. Just got instument cluster repaired last week, and learned a little I will be glad to share. Thanks to everbody. vbm
Great Thread! I had a 2003 ext cab that didnt have any rattles in the steering but did have the groaning from the power steering pump. Traded it before I fixed it. I have 2 friends that have 02 Tahoe's and the steering on both is horrible. I now have some things I can look into on them.
Update. Installed it this afternoon, not a hard install, just tight working space and need patience with getting the old one out and new one in, but night an day difference. Much smoother steering, not as loose as before. And I swear it is quieter on the highway now too. Definitely worth the $24!!! Thanks a ton for the writeup, I would have never known otherwise
I have a similar BB rattle in my 2006, it started with a column rattle at idle in park. The rattle has now evolved into the sound of BB's or bad bearing/sand sound occasionally when I am driving or making a turn.
thanks for the info! I'm going to try the clamp method first
I googled the GM PT# and came up with this from Dorman
http://www.dormanproducts.com/mobile...6-905-512.aspx
Does the new, revised bearing only last 5 months? Anyone else had the new, revised one crap out?
man i just looked at the sticky on this SIMILAR subject 3 days ago. mine has had the notorious rattle since I bought it and when i did buy it in 2007 they said grease it but the rattle comes back in 10-12,000 miles. well low and behold it came back almost right at 10,000. so i never worried with it bc i figured it'd have to be a recall after seeing so many people have this problem and then replace the steering box and it'd be fine but some people still have the problem. But mine is similar to the "jknox" problem that is moans more turning left. checked my PS fluid seemed somewhat low so i was going to try that first but i hope someone has an update on the new bearings. if that fixes im going to look into it more. this along with the sticky is very helpful
