Stock 1/4 times
Old 11-05-2007, 06:31 PM
  #191
joshua022's Avatar
Originally Posted by jakebdb56
this is an old pic. but that's still kinda what's on there. Right now I have some stainless lines that run around the k&n tube that I run liquid C02 through. the lines I put underneath the header wrap, and then on top I used some more fiberglass wrap to insulate it all. makes it a wee bit chilly . It's a big PITA to do and it's only just to see if it works. I spent probably 180 bux on the setup to do it right and I fabbed the pieces my self. the tank was a freebie (usually costs 150) from my old place of work. it drops the IAT about 30-50* instantly on a hot day. It's kinda illegal to have the bottle in the truck so I don't keep it in there haha. Nitrous is obviously a LOT more economical and cheaper in the long run, but being a nerd and having nothing to do on saturdays I gave it a shot. don't have any dyno numbers, but would like to get some. I have the IAT adder put in an extra 3* of WOT timing when the c02 is engaged.
btw, not sure if it causes condensation, it doesn't appear to though.
note: it's the 77 series tube that's metal. plastic tube wouldn't have worked too well
Nice set-up, I have wondered how insulating the intake tube might help.
Old 11-05-2007, 07:48 PM
  #192
jakebdb56's Avatar
thanks man, it really helps just using the fiberglass header wrap. I wish that the c02 system was a little better. I almost thought about tapping into the a/c where the intake would be constantly cooled. Not a bad idea for us Texas guys in this damn heat.
I have a log somewhere that shows the difference with the wrapped intake. Off the bat it was around 15* taken off with just the fiberglass wrap.
Anyways, bout to order some nitrous here soon.
Old 11-05-2007, 09:55 PM
  #193
regency's Avatar
well guys i believe that on the perfect day that DODGE 345 HP (in stock form) motor should run very low 13's i mean come on a stock 6.0 with the same CHEVY 345 HP (in stock form) is running very low 13's if not 12's i know the cubes are different but you need to look at the HP/TQ ratings for a comparison here. in the same comparison the LS1 has almost the same power to weight ratio as the hemi and 6.0 because its an aluminum block. so i can see these running the same or very close to the same times. now my setup needs work as in a converter which ill have wednesday, shortbelt, 17's up front, O2's, and tune to be played with some more, and it should be running strong hopefully!!!!!
Old 11-06-2007, 06:32 AM
  #194
joshua022's Avatar
I agree it is possible in a regular cab, but I don't believe a CC can do it as easily without A LOT of weight reduction. IMHO
Old 11-17-2007, 11:44 AM
  #195
nick993's Avatar
dang i need to move to the east coast. your trucks are damn fast. i guess the smog is taking 100hp from my truck.
ARC
57
02-21-2022 10:54 AM
thunder550
10-08-2015 04:53 PM
fastjweb
08-15-2015 10:47 AM
Choda
07-21-2015 03:47 PM
fcompean
07-15-2015 09:55 PM
Quick Reply: Stock 1/4 times
