Stuck crank sprocket; dampener on 5.3?
I'm doing a cam and timing set swap on my 5.3 and can't get the crankshaft timing chain sprocket off! I thought they were just a slip-fit over the shaft and key, not pressed on. Has anyone had this problem, and how did you solve it?
Also, does GM install a timing chain dampener on any of the truck LS engines? Can the LS2 dampeners be used on a 5.3, and would it help or be worth it?
Thanks for any help.
I'm working on an L33 5.3, and the block has 2 threaded holes between the cam and crank. I've seen pics of an LS2 with a timing chain dampener, so that's why my question about it. I went ahead and bought one to see if it would work in a 5.3, and it's an exact fit! Here are a few pics of it:
The LS2 dampener is GM part #12588670 and includes the 2 mounting bolts if anyone is interested.
WarbirdLS1
08-08-2015 10:53 PM
MileHighSierra
07-22-2015 11:19 PM
