stuck fan on water pump
Old 03-29-2013 | 12:15 PM
40series's Avatar
Default stuck fan on water pump
i need help in getting the fan off the water pum its off the truck n ive tried everything . the nut is not threaded an it only slip fits over the the hub on the pump bit it wont budge this shouldnt bee this hard pipe wrench or banging from the rear does not get it moving
help fellas
Old 03-29-2013 | 12:22 PM
03sierraslt's Avatar
Never seen one that was not threaded. You sure about that.
Old 03-29-2013 | 12:34 PM
40series's Avatar
Default maybe i over looked something
i looked @ thhe replacement part n the new pump dont seem to look threaded @ the fan this job is down due to this life sucks now i can do this
Old 03-29-2013 | 12:38 PM
thunder550's Avatar
High on diesel fumes
Your new water pump might be designed for an electric fan truck if it's not threaded. For the fan on your current truck, sometimes putting a big pipe wrench or something similar on the fan nut and whacking it with a mallet or sledge hammer will do the trick (have to have the belt on it still to keep the pulley from turning). I've heard of people taking power chisels and hitting the nut directly with them to break it loose as well.
Old 03-29-2013 | 12:54 PM
40series's Avatar
Default thanks man
i was thinking air chisel too might have to go out n get one of those
Old 03-29-2013 | 02:00 PM
40series's Avatar
Default air chisel not working
air chisel is NOT WORKING on this fan nut WTF im getting pissed my truck is down **** !
this thing is not even budging
Old 03-29-2013 | 02:35 PM
I found the easiest way is with the pump on the truck and the belt on to hold the pulley. Put a big crescent wrench on the nut and give it a hit with a hammer.
Old 03-29-2013 | 06:50 PM
1994Vmax's Avatar
I use the blade holding tool that came with my makita grinder to hold the water pump pulley. The pulley has holes in it and just slip one of the teeth on the tool in and then apply pressure while I use a 24" crecent wrench on the fan pulley. Comes off like butter....... and then goes in the trash for e fans lol.
Old 03-29-2013 | 08:02 PM
GMCtrk's Avatar
Spray penetrating oil on the nut/threads. Then stuff a towel in the sepentine belt area to lock up the belt. Then put a huge crescent wrench on the nut and take baseball bat swings at it with a rubber mallet. That's my method. The key is having the crescent wrench tight on the nut.
Old 03-29-2013 | 08:05 PM
40series's Avatar
a i r hammer didint work wtf some thing is wrong with this picture ,,,... i will mention the fan was hitting the shroud a bit on turns ' sometimes' idk if it wore some how and created some un even suface so the fan cant come off????? i know this is a stretch .... ive done this job before and that NUT is a mother f er i ve braced it with punches through the hole thing ... dint work , pipe wrench didnt work,,, air hammer not working .................
Quick Reply: stuck fan on water pump
