Stumped on MPG issue
Hey all,
I've got a '99 Sierra z71 5.3 that I've been trying to track down a gas mileage issue with. I used to average about 17, let it sit for about a year, started it once or twice per month. Just recently put it back into service and now get 12 mpg. Short of a slight stumble at idle it runs great. Truck has 140k miles.
I've replaced:
plugs with NGK-TR55
New barrel type ignition coils
MSD plug wires
EGR valve cleaned and solenoid checked, no issues
Air filter cleaned and oiled
Throttle body removed and cleaned
Intake cleaned
PCV replaced
O2 sensors replaced with NGK
New 28lb fuel injectors
Fuel filter replaced
Fuel Pressure regulator checked, no leaking diaghram
MAF cleaned
All fluids replaced with synthetic
I don't drive with a heavy foot. Short of new cats, I don't know what's left to check. Any ideas would be much appreciated.
How can the cats be checked?
Also, how to check for misfire?
Anyone seen a significant drop with the "up to 10% ethanol" put in the regular gas?
Thanks for any help
I've replaced:
plugs with NGK-TR55
MSD plug wires
Intake cleaned
PCV replaced
MAF cleaned
Thanks for any help
Forgot to mention those injectors just went in this morning, so not the source, but when I see the next drop I'll know why. They did clean up the idle though.
How is the pressure test on the cats done?
Thanks!
Thanks!
That's my latest test, I just put them in this morning, won't know how they're doing until I get another tank through. Looks promising though, really smoothed out the idle, if it weren't for a random slight stumble you wouldn't know it was running inside.
