Summer project: Go faster or handle/hook better
Resident Retard
Well i am still deciding it is kinda a tough choice. If i do ladder bars or a 4-link it will be mounted on the outside of the frame rails which i have seen done a few times. I am not sure how that would affect the articulation. Then again if i decide to mount them on the inside of the frame rails i will have to swap to a fuel cell, which i will do eventually. So i want to do things in order so i dont waste money redoing the same thing multiple times.
Well when the wife goes out of town for 3 weeks during the summer I usually do some kinda project... I am having a hard time deciding on what todo this year... My choices are a cam swap and 1 7/8 headers or Ladder bar/4-link, watts link and coil overs.
OPTION 1
Comps LXL lobes
226/230 .605/.609 LSA and ICL to be determined after some math
230/234 .609/.612 LSA and ICL to be determined after some math
and TPS Fbody 1 7/8 headers
Texas Speed 1 7/8" Long Tube Headers
OPTION 2
36" BATTLE CRUISER LADDER BARS - ADJUSTABLE LOWER TUBE by Chris Alston's Chassis Works
a custom 4-link
a off the shelf or custom Watts link
QA1 adjustable coil overs...
OPTION 1
Comps LXL lobes
OPTION 2
a custom 4-link
The ladder bar is simpler but again you may still have to make small adjustments.
I am not saying you can't run fast with a ladder bar, but there is a point when you can no longer transfer the power effectively with them. You Can't pin point the exact HP range because weight, chassis configuration, ride height an so on all have an effect on it. I believe it has been said that around the 900 hp range in a door car is around the limit. I can't find my chassis books right now to confirm. Keep in mind those around the 3000 pound range.
Its actually a cross between a ladderbar and a truck arm. More of a high bird ladderbar set up if anything.
Jerry Bickel has a book called "Jerry Bickel's Complete Guide to Chassis Performance" and then there is another book called "Door Slammers: The Chassis Book" by Dave morgan
Resident Retard
Yep still on a 10bolt. I am not really planning huge power in the future. I just really enjoy learning new things and building stuff. Eventually after i buy a new car for the wife i am going to start building a race car. But that is about a year out
Resident Retard
I started looking at some 4-link software today, i think i am going to order this:
4 (four) Link Software Program for Drag Racing Suspension
Seems todo everything i will need.
also i have access to a set of scales but just for ***** I looked up some pricing on them... $700-$1000 depending on the features... Kinda spendy....
