SVO injectors?
Adkoonerstrator
The 44lb(at 58psi) multec II's are the biggest direct swap injectors there are for us truckers. Actually, they are good for over 500 flywheel hp so they might be ok for ya.
What size injector are you looking for?
it is good idea to switch to the bosh style injectors, because once you do the conversion... you pretty much can swap to a lower or higher flow rate injector if need be.
