Swapping MAF's
Swapping MAF's
I'm thinking about this more from an appearance standpoint than performance, but here's the question. Has anyone considered/swapped the MAF in the trucks for one from an F-body? I realize the truck has a 4 or 5 wire hook up on the MAF for MAF signal and IAT signal. The thought I'd had was swapping over to the Fbody MAF and putting an IAT in the intake tube. Basically just pulling the wires from the 4 wire plug that is there now and connecting them to a 3 wire plug for the MAF and a 2 wire plug for the IAT. Would this work or has anyone tried it?
As stated originally....looking at it more from an appearance standpoint. But I can definately see the advantage of putting the IAT in the manifold.
Just wanting to know if my thoughts would work physically before I go cutting wires and all under the hood, cause I don't see why it wouldn't work on paper.
Thanks man. I went to Lingenfelter's site to take a look at that MAF and see that they actually have the adapter for what I was considering doing. Thanks for the post cause it got me going in the right direction.
Originally Posted by Yelo
MAF sizes are different between the trucks and F-bodies....the truck's is 85mm vs. 75mm for the F-body
Hmmm...interesting cause side by side the ones on my Formula and Truck are the same size and I know the Formula's is stock cause I'm the original owner. As is the truck's because it's a GM MAF and is the MAF with the IAT in it.
It's possible I'm wrong, but everything I've researched says the MAF with the divorced IAT is 75mm (used on f and some y-bodies), and the MAF with the integrated IAT is 85mm (used on Z06's and trucks)
HectorM52
08-18-2015 12:40 PM
noproblems209
08-10-2015 06:57 PM
rojeho
08-08-2015 07:20 PM
