Is there any performance diff in the 5.3 LMG vs LY5
I personally preferr the E85 setup. This will allow you to run E85 with boost if you want to and still have the pcm pick that up. The stock pump on the E85 vehicles commonly are big enough to flow all of the fuel you're going to need for a boosted 5.3L. A TVS1900 on that engine would be bad ***. As for using the stock injectors under boost, even the 38's on the E85 engine aren't really big enough for much boost on a good running 5.3L and a returnless fuel system. On an E85 truck I'd go to 60's or bigger.
what is the size of the gas injectors and E85 injectors for comparison?
Isnt the entire fuel system SS on the E85 or is it the same on both?
Snake Eater
01-03-2006 02:10 PM
2008, 53, 53l, boost, capable, difference, engine, flex, injectors, lmg, ly5, magnacharger, performance, supercharge, vortec
