Is there anyway to get rid of the damn "no seatbelt" chime?
blownerator
Originally Posted by LesPaul
no you cant tune it out... all it is, is your buckle acts like a switch once its in it make a compleate circuit and shuts off the light in your dash and the chime all you have to do is take off the seatbelt cover and splice the 2 wires together
WRONG!
Seatbelt vs. Spark vs. PE vs. window speed table will handle that just fine.
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
I know! I know! I know!!! Use the damn thing and it won't ever chime at you again. But I appologize for your ignorance if you have a 'good' reason for not wearing your seatbelt...
The chime noise goes through the radio, I was told if you replace the radio that you can make all the chime noises go away.
I found this article on how to silence the chime when the key is in, it did not work on the 2006. It made the radio stop working.
http://www.gm-trucks.com/forums/inde...opic=33087&hl=
jscherbs
03-24-2017 07:20 PM
