Throttle body bump stop grind?
Formerly one92rs
you need to stay under 4.65. that is the max. you probe the red lead from your meter to the blue wire on the bottom of the tps. then to ground for the other lead. closed voltage should be around .52 top .65. and the opening voltage should be no more than 4.65. just turn the key on and check your readings.
Originally Posted by Y2K Silverado
Well I guess the HPP resets the code. After I use it to load either the same program or a new one, the SES light isn't there any more.
Jim
Jim
I don't know about the HPP#, but the Predator can read codes, run code tests (all or specefic ones) tell you what codes and the faults are when the SES light comes on AND CLEAR THEM. A very cool tool if you ask me. You can find them used on the boards or Ebay, if they're cheap enough they're good to have just for the diagnostic capabilities! IMHO of course!
smokeshow
08-23-2015 08:23 PM
GreyChevy
07-07-2015 08:57 PM
Gadgetized
07-07-2015 04:40 PM
