Top engine cleaner seems to have worked.
Originally Posted by Snafudilligad
Why not use SeaFoam?
Still readily available in California at a NAPA or equivalent parts house near you.
Adkoonerstrator
Originally Posted by MacADaYear
Is it the same thing or just as good?
The stuff dissolves crud on contact. My TB sparkles now.
Adkoonerstrator
Originally Posted by ILLNALI
damn I cant even ask a question?
- Truck had oily intake and crudded up TB.
- Also, had bad KR which caused very low timing.
- Bought AMW catch can and top end cleaner to try and cure oily intake and KR.
- Installed catch can and used top end cleaner.
- Truck ran like crap at first but, now runs great.
- Intake is clean, AMW catch can works, timing is way up, KR is non existant.
There ya go.
Originally Posted by XLR8NSS
Jeez, here are your cliff notes. I thought you were being an ***, but, I guess you really wanted the cliff notes.
There ya go.
There ya go.
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
Sure, how much you want? I guess you just get it at the parts department?
Here is a picture of exactly what I want, you can pick it up at any GM parts dept. I believe they come in cases of 12. I'll take one case please
How did you spray it in the TB? Does it come in an aerosol? I did mine through the PCV on the old motor. It didn't make a lick of difference IMO, but maybe she was too far gone between EGR and PCV. I'm going to run a can through 6.0l since I didn't have the catch can on there for the first 3000 miles.
Adkoonerstrator
Mac and Chingon - Do you both want a case? You better pay me for this stuff after I buy it.
OBX - The Amsoil Power Foam sprayed outta an aerosol can. It came out as a foam, with the TB cracked a bit it got sucked right into the engine right around the TB blade. After seeing how much oil was in the catch can after a few hundred miles I would definately run a can through.
