Tow haul doesnt work
Old 10-17-2010, 05:27 PM
Landcruisin60's Avatar
Default Tow haul doesnt work
Hey guys I have a new to me 01 Silverado 2500 2wd. Tow haul hasnt work since I bought the truck so I researched on here and found that the wires breaking is a common issue. So I checked and guess what mine were broken. So I ordered a shifter off eBay and the listing specifically said tow/haul works on the shifter. So I installed the new shifter and nothing. Still doesnt work. Is there a fuse that could be blown? I hope its not an issue with my PCM or something stupid like that.
Thanks for the help
Old 10-17-2010, 09:35 PM
SilverDog's Avatar
Mine stopped working once, had a small break in the orange wire going from the shifter. I assume when you reinstalled the new shifter you reconnected the wire?
Old 10-18-2010, 01:20 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
If it was a used shifter, the wire strands are probably broken inside the insulation. I'd pull the clamshells & check that first. Never seen anything else ever cause this.
Old 10-18-2010, 09:31 AM
I'm pretty sure the wires are fine. But I can check the resistance in the wires.
Had a little side thought there. If I were to momentarily cross the wires at the plug that should turn on tow/haul, right? If it does then the issue is in the wiring or switch. If not then the issue is somewhere else. Would this work?
Old 10-18-2010, 09:33 AM
11 sec. Truck Mod
TIM Z's Avatar
hmmm, every one ive seen the wires were broke. They have to be the smallest gauge wires ive ever seen!
Old 10-20-2010, 12:53 AM
I believe the button is activating tow/haul just the light isnt coming on. Any idea what would cause that?
Old 10-20-2010, 07:45 PM
SnakeOiler's Avatar
You should be able to tell if tow/haul is activated just by driving it. The shift points are way different.
burned out bulb would answer your question.
Old 10-20-2010, 07:50 PM
Where's the Beef?
viciousknid's Avatar
agreed. The bulb could just be blown on the cluster. when driving about 25mph push the button and see if the converter unlocks. RPMs should increase 2-300rpm
Old 10-21-2010, 01:29 AM
Ok that makes sense. From reading the owners manual I thought that the little information center light screen thing on the left is where it says tow haul. But after some internet research I see there is actually a light on the upper right of the cluster that says tow/haul. I'll check that bulb.
Old 10-21-2010, 10:00 AM
Where's the Beef?
it'll just be a trailer that lights up.
Quick Reply: Tow haul doesnt work
