Tow Pig Cam Swap
Old 07-28-2024, 03:42 PM
11 Second Club
the_merv's Avatar
I don't believe so, we have a 2007 Chevy 2500HD Flatbed at my work and it's a Clutch Fan. LQ4/4L80E truck. Early 2007 so still a GMT800 cat eye.
Old 07-29-2024, 08:50 AM
shakenfake's Avatar
Received 1,271 Likes on 970 Posts
No 3/4 or 1 ton trucks have electric fans. They still use a clutch fan today or only just recently switched to electric.
The following 2 users liked this post by shakenfake:
Bluecollar Hotrods (07-29-2024), strutaeng (07-29-2024)
Old 07-29-2024, 09:54 AM
strutaeng's Avatar
I did the Summit SUM-8718R1 to my 06 Suburban 2500 a few months ago. I did an engine refresh job because I had an intermittent lifter tick and just didn't want to go back with the stock cam. I used some remachined 317 heads I had for another engine build I have going on.
I haven't towed with it, but it's pretty torque-y down low and seemed like a good upgrade to me.
Old 07-29-2024, 10:35 AM
10 Second Club
I'm looking at this cam https://cammotion.com/camshafts/6-0-...204-212-116-4/
a set of milled 799s I have on hand
Long tube headers, and a TBSS intake for my 2003 ECSB 2500HD 4X4
I want to set it up for flex fuel as well. Hoping all that will make it better, without sacrificing any low end grunt.
Old 07-29-2024, 12:57 PM
shakenfake's Avatar
@strutaeng Did you gain any MPGs?
Old 07-29-2024, 01:20 PM
strutaeng's Avatar
No. I think I lost some MPG actually, LoL.
I've been seeing like 10.8-11.2 MPG, but this has been 80 city/20 highway. I was previously at 12 MPG since I had bought the truck...
Old 07-29-2024, 08:28 PM
11 Second Club
the_merv's Avatar
I picked up like 1.4mpg but I also tuned the O2 Sensor switch points. I lean it out a hair in the cruising ranges, learned that one a long time ago.
Funny you mention Lifter tick, my truck has the stock 2001 LQ4 with a hair under 200k miles. Back in 2015 I did the Oil Pan Gasket, replaced the O-Ring on the Pickup Tube with the new red one. It had a Lifter tick before I did that, it's been gone since. Idles 60psi cold/50psi hot oil pressure with 10W30.
The following 2 users liked this post by the_merv:
Bluecollar Hotrods (08-20-2024), strutaeng (07-29-2024)
Old 07-31-2024, 06:50 AM
smokinlmm's Avatar
That Monte Carlo looks killer in your sig….👍🏼
the_merv (08-17-2024)
Old 08-17-2024, 02:18 PM
11 Second Club
the_merv's Avatar
Thanks man, just a Cammed 6.0l & Built T56 6spd car that will throw down.
Build thread is in the sig.
https://ls1tech.com/forums/conversio...t56-build.html
I've lowered it since, I need it and the Z06 out of the garage one day for a more recent pic.
Old 08-19-2024, 07:50 PM
Fullpower's Avatar
Originally Posted by the_merv
tuned the O2 Sensor switch points. I lean it out a hair in the cruising ranges, .
What kind of AFR do you shoot for at cruise ?
How much of an offset will you run on narrowband O2 ?
Particular brand sensor that will behave itself better when operationg out of STOICH ?
ie Bosch, NTK, Denso ?
Thanks !!
Quick Reply: Tow Pig Cam Swap
