Tranny/Engine won't seperate!
Old 10-18-2009, 02:00 AM
9 Second Truck Club
stock48's Avatar
Originally Posted by dirt track racer 81
try jacking the trans up and down as you pry it
Thats what I would try after soaking it with the WD, and make sure you got the bolt at the top of the V.
Old 10-18-2009, 08:15 AM
NoShow's Avatar
Originally Posted by 99LsSilverado
If you have an air hammer to hit the alignment pins from the engine side or you could use a regular hammer and a punch
There's no room for a punch on the pass side but I think I have room on the D side. That's a good idea
Did you mean hit it from the tranny side?
Old 10-20-2009, 02:30 AM
99LsSilverado's Avatar
Yeah from the tranny side. It is what I had to do to get mine seperated. But I also knocked them out all the way and replaced them. It took a little while but with some PB blaster it worked great.
Old 10-20-2009, 02:37 PM
12 Second Club
the alum likes to bond to the engine... u just have to get a pry bar or large screwdriver in the little slots that are cut in the bellhousing. just pry and pry and maybe get a deadblow mallet or be gentle with a ball peen hammer and tap around the mounting flange. i had this problem a couple times... and if that doesnt work, then you just have to get physical with it
Old 10-20-2009, 02:49 PM
CashDudeHomie's Avatar
There is a little notch cut in each side. You should be able to get a screwdriver in and pry a bit. Pry it until you can jam another screwdriver in a few inches over. Then do it on the other notch. Once you get 3 or 4 in you can tap them with a hammer until the pins finally break loose. It will pop pretty loud when they break loose. Be sure it is properly supported.
Old 10-20-2009, 07:44 PM
NoShow's Avatar
We got er apart on Sun. Thanks for the advice. We had two big pry bars, one on each side to work it loose
dsbodley
11-14-2015 09:46 PM
wickedRCSB
10-30-2015 09:45 PM
nabozny21
10-17-2015 07:47 PM
old motorhead
09-29-2015 08:22 PM
trxmxzx
09-29-2015 07:42 AM
Quick Reply: Tranny/Engine won't seperate!
