truck died, no fuel pressure Help!
all last week my truck would hesitate to start and run weird until it was warm and would spudder over 4000rpms. about 5 days later I was idling and it just killed. I tried to restart it, it would kind of fire but sounded like it was starving for fuel, It sounded like it was getting less and less fuel as I tried to start it until it sounded like it had no gas. The stater just spun the engine but i wouldn't turn over at all.
When i turn the key I don't hear the pump kicking on at all and there is 0psi on the rails off the schrader valve. I do believe I picked up some bad gas right before it started running funny but that was only a 1/4 tank and i filled the rest up with good gas about 50 miles later and during all of this my check engine light never came on.
I think I need a new pump but want to know for sure before I buy it. what do you guys think? thanks
its a 07 classic flex fuel if that makes a difference. im about to order this if it right. isn't there a walbro 255 kit that comes with the hose and stuff for trucks?
http://www.racetronix.biz/itemdesc.a...SS340M&eq=&Tp=
I wouldnt even bother ordering just the pump. You can get the complete sending unit from Racetronix with a 255 pump for 225 bucks, also comes with a new tank seal. All you have to do is drop it in.
i don't care about warranties, is this it? this is the only one that specifies 5.3 at all
http://www.racetronix.biz/itemdesc.a...%2D008&eq=&Tp=
That pump shows only up to 03 year models. In 04 or 05 they switched to an in tank fuel filter so I don't think that one will work unless you add a filter but someone else should chime in to be sure. Unless the "Filter Socks" on it are supposed to do the job?
