Truck problem
Old 12-01-2009, 08:06 PM
Registered User
SILVANO 21's Avatar
Default Truck problem
i have a 99 chevy silverado new body style 4.8 and ever since i took of my tranny and put a stall it started choking if i hit it off a take of it just sits there bogging down so i took the stall back of and put it back how it was and it still does it and just driving it normal still does it. I checked fuel pressure, spark, and i have changed every sensor there is 2 change and is still does it Do yall have any ideas on what can it be
Old 12-01-2009, 08:19 PM
BOSS302's Avatar
clogged cats? Do you have a tune?
Old 12-02-2009, 12:14 PM
Matt G6007's Avatar
ok my friends at work but i can help a little bit....
he has no cats, tune by file, stock converter, but he does have an exaust leak from where he disconnected the egr from the manifolds, and
Old 12-02-2009, 10:47 PM
Registered User
SILVANO 21's Avatar
i dont have cats yeah am tuned with file
Old 12-08-2009, 07:00 PM
Registered User
SILVANO 21's Avatar
what yall guys think any more ideas on what it could be i changed tune and computer and it still does it do yall think it could be the fuel pump???
Old 12-08-2009, 07:16 PM
Where's the Beef?
viciousknid's Avatar
I have NO idea what that means.
Google the word "Sentence" please. It's hard for people to help you if we don't know wtf your saying just because you can't end a sentence with a period before you start a new thought.
It doesn't sound like it has anything to do with your converter but Cats maybe. Did you pinch any wires when you put the trans back in?
Old 12-09-2009, 01:58 PM
midnight_bowtie's Avatar
I think he meant that either at WOT or normal driving it bogs. He doesn't have CATS and is tuned for them.
Old 12-12-2009, 06:24 PM
Registered User
SILVANO 21's Avatar
I hooked up a scanner today and all the sensor seem 2 be working fine.The only thing i saw was that the timing sits at 30 in park about 22 in gear and when u try 2 power brake it it goes negative and looses power.Also that Tranny i put was off a Camaro i dont now if that would cause all these problems,Since that was the thing i change when it fucked up.
Old 12-12-2009, 08:19 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Check to see if you smashed a harness between the transmission bellhousing and engine.
Old 12-13-2009, 02:02 AM
Registered User
SILVANO 21's Avatar
ill check that tomorrow thanks
Quick Reply: Truck problem
