Truck shifts out of park without the brake after hydroboost conversion
That's awesome , sweet upgrade , glad it's working good for ya .
Wonder what year they started putting hydro boost on tahoe s ? My wife's 05 z71 has hydro boost .
NSBU switch , as its called on my dmax is the switch connected to the linkage telling the vehicle what gear position it's in , having a brain fart on what the 60/80e uses , but I thought it might be a place to check.
I did the swap a while ago, but out of habit always pushed the brake in when shifting out of park. The other day I was in a hurry and punched the brake and shifted, then realized I had already let off the brake before I had moved the shifter, then tried it without touching the brake and was surprised to see the shifter would go to any gear from P without the brake.
I checked mine out of curiosity and it works exactly the same as it did before the swath, unable to shift out of park without the brake engaged.
I'm actually wondering if this is a separate problem at the steering column.
