Truck squeaks
Truck squeaks
Its driving me crazy. I have this sexy bitch of truck. And its fine when its just sitting there, you know, looking all sexy. But, if the suspension moves its going to squeak. Its only in the leaf springs. Any one have any helpful comments.
12 Second Club
Find the mouse and get rid of it
J/K
I would lubricate all the moving parts underneath there.
My shocks would squeak, untill I changed them out. but I would WD40 anything that can move under there untill I found what was sqeaking
J/K
If so
Did you torque the bolts to 65 ft/lbs -
when the truck is back on the ground ??
- if not - it will put the bushings in the leafs in a bind and they will squeak like a....
also try some white lith grease on the sides of the bushings...
There is a little pad between the leaves where they contact each other. If these pads wear out, it will cause a squeaking noise. Not sure where to get new ones at, but this could be your problem.
Josh Hucks
Josh Hucks
Suburban2500
07-19-2015 04:50 PM
Mossyoakglock
07-17-2015 08:30 AM
Nimoryan
07-05-2015 03:50 PM
