Unknown driver, ABS light, batt light, etc.
They all show up while im driving, my gas light stays on and the needle stays at E. my e-brake light stays on. and there is no underline to show what gear it is in. the truck drives like normal. whats going on?
Piss Pumps for Sale
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
1 Post
I had this problem back in the winter, clean your grounds on the driver side cab mount, everything should go back to normal after that
Ok, im bring this back. its gotten to where its on all the time. just before it stayed on, i noticed its when i hit the switches. so i believe something is loose even though i checked every ground i could see. where exactly is this ground at the driver side body mount? where the cab bolts to the frame, or the firewall?
Piss Pumps for Sale
1 Post
its the body mount mount on the frame right at the front of your drivers side door, there should be 2-3 wires bolted to the frame, they or the frame may have corrosion on them.
97aztecgt
08-13-2015 02:11 PM
