Using Hydroboost PS Pump w/o hydroboost
Old 06-10-2008 | 06:11 PM
GA95DCMSS's Avatar
Default Using Hydroboost PS Pump w/o hydroboost
Alright, I'm in the process of putting a 6.0L LQ4 in my 1995 impala ss...but I have a question. The PS pump that came with the engine came with 3 outlets...one being for the hydroboost I'm guessing. Is there anyway I can use this without the hydroboost function? I'm also not completely sure which is the return fitting either...I'm guessing the pressure side is the threaded lower hole. Any suggestions?
Old 06-10-2008 | 07:51 PM
1BadAction's Avatar
Registered abuser
I am converting to hydroboost on my truck that originally didnt have it. want to swap PS pumps?
Old 06-10-2008 | 07:59 PM
KySilverado's Avatar
Only difference external is one extra return port. Just cap off the one the points upward. The screw in is the pressure side.
Old 06-11-2008 | 08:41 PM
TrickyTransAm's Avatar
Use the lower return tube for your return from the cooler.
Cap the Upper tube. like KYSilverado said.
Chavette
10-28-2015 08:33 PM
silver-mod-o
09-19-2015 09:46 PM
chopperloco
09-18-2015 07:44 PM
rednekferlife101
09-14-2015 06:27 PM
InsaneDomestics
09-10-2015 06:32 AM
