Using a TCM-2650
#131
Could always hit the junkyard and cut the tunnel out and weld it in there. That is what I would do and would totally be worth it.
#132
Registered abuser
Another FTW guy doing a 6L swap! Got me out of the woodwork on this one, lol. I have a 6L90 that was going to go behind a 582 big block in the suburban, NP205 iron case, etc... but it's now going to go behind a turbo SBC in my 94 Blazer with Termi X ECM interfaced for shift spark cut (Similar to how Scrapmetal sleepers on youtube does it) and a 29 spline swapped NP241 floor shift - So just now getting my head back in the game.
#133
That should be way easier in another car than in a GMT-800. Older cars are simpler to wire up everything it seems. LS1Tech has a few guys doing it.
strutaeng (04-17-2023)
#135
Laaaaaaaame
I was looking at buying a dirtbike this weekend. You nerds have talked me into it sort of lol
#137
Alright,so I got this started and all the old stuff out and got the 2650 mounted and some rough wire routing. I got some T-taps for taping into the wires(yes I know they are crap, but they are also temporary, if they work out in the locations i have them, then I'll do it right).
I dont have pics yet but I mounted the 2650 to the fuse box cover under the hood, close to the brake booster and BCM on the firewall, since i had a hole in the firewall for the clutch master, I used that to run the ODBII port and the yellow 12v switched power supply in to the cab. I used the nearest chassis ground on the firewall for the power ground. for the 12v power from the 2650 i use one of the post under the fuse box cover in the engine bay for power, I'm not 100% sure that will work but I'm gonna try it. all this is subject to change I'll update as i change stuff. there are a few cables and digital inputs that I wont be using so I'll just tape those up and hide them somewhere for now, eventually if I dont ever use them, I'll cut them down and tape them up.
I tapped the TPS inputs via the purple and black wires at the TB
for the RPM, I taped injector #1, we'll see how that works out.
more updates as i get more done.
firebladeJJ (04-24-2023)
#139
Thats just the stuff I did for the 2650, I also put the shift cable in, the auto shifter lever, did a shitty install of the trans cooler, drilled a hole in my AC condenser at the same time. you know just trying to fix more than i screw up.
My daughter turned 16 last week and is itching to drive her truck, she's been blowing me up everyday to see if i have my truck running. Motivation to work faster, because teenage girls are annoy AF!
All that and I havent even put the transmission in yet. so I dont even know if it will mount to the crossmember yet or if the driveshaft is the right.
#140
I had to modify my crossmember and move it 2 inches back to clear the pan for removal.
