Using a TCM-2650
Old 04-28-2023, 11:12 AM
  #151
firebladeJJ's Avatar
this is what i got back from ZGP this morning: The output is 2000 ppm per mile. You can also get a speed from pin 16 on the transmission connector
Old 04-28-2023, 11:34 AM
  #152
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
Old 04-28-2023, 01:16 PM
  #153
Alanis001's Avatar
I did run an extra pin from 16 on the tcm but haven’t tried hooking it up. I will try tmw and see if I can get it to work.
Old 04-29-2023, 10:11 AM
  #154
Alanis001's Avatar
So I tried running a wire from pin 16 on tcm to the high side, low side even the cluster speed circuits and nothing. Debating on dropping the pan and trying to wire into the speed sensor🤔
Old 04-30-2023, 03:43 PM
  #155
looking at the diagnostics for the speed sensor on the 6l80, it looks like it generates a 8.3-9.3V signal and the one on the GMT800 for the speed signal is something like a 5V signal.
on my truck when i had the sensor unplugged at the T56, it would give a rear ABS DTC
I dont know if that helps any or what to do with that information but there it is.
Old 05-01-2023, 08:58 AM
  #156
@Alanis001 how did you handle your Park/Neutral Safety box? Mine does not fit to the side of the 6l80. Run new wires or tap?
Old 05-01-2023, 01:13 PM
  #157
https://sirhclabs.com/product/cortex...ensor-adapter/
Possible solution, another module but it looks simple
Old 05-01-2023, 02:38 PM
  #158
arthursc2's Avatar
Received 1,501 Likes on 1,100 Posts
Dude is local to me! Maybe I can do some networking
firebladeJJ (05-01-2023)
Old 05-01-2023, 02:47 PM
  #159
shakenfake's Avatar
Maybe you could just like, I don't know, do your 6L80 swap and drive over there yourself and ask him
Old 05-01-2023, 03:23 PM
  #160
arthursc2's Avatar
That sounds like work. No thanks
Plus, if I don't have a speedo.... I might get a ticket. Oof
zz454Chevelle67 (05-02-2023)
Quick Reply: Using a TCM-2650
