Using a TCM-2650
Old 05-25-2023, 11:18 PM
  #191
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by firebladeJJ
I pulled the cal off the 6l80, some of the stuff in there looks strange to me, especially when compared to the stock 6l80 cal from my 2012. someone more knowledgeable that me please take a look at it.
So it looks like the 24270599 OS is for a 2014 application.
It doesn't display a vin on my end so that's all I know.
I know things changed through the years and not everything is fully mapped.
What all is different from your 2012?
Old 05-26-2023, 08:32 AM
  #192
firebladeJJ's Avatar
It's seems like the tc lockups were crazy early and some of the shift timing and pressures were all different. That could just bee the difference between 2012 and 2014. I'll have to find a similar stock 2014 tune file and compare, or post the 2012 and let you look too. Also, what I don't know could fill the grand canyon so there's that too.
Old 05-26-2023, 12:21 PM
  #193
Alanis001's Avatar
I had to turn off my tcc lock up in all gears to prevent the harsh shifting in regular driving
Old 05-26-2023, 12:54 PM
  #194
Solution for the abs and speedo
https://www.summitracing.com/parts/dak-sgi-100bt
arthursc2 (05-26-2023)
Old 05-26-2023, 01:54 PM
  #195
1FastBrick's Avatar
Edit: never mind I am thinking about an OEM system, not using this aftermarket system
Old 05-26-2023, 04:31 PM
  #196
Dang!! I didn't get to see the first response
Old 05-26-2023, 07:42 PM
  #197
1FastBrick's Avatar
Was about the unit not being compatible with the ABS System
Old 05-26-2023, 09:10 PM
  #198
Yeah there is a warning about that but as long as your not trying ti adjust the abs signal with the box vs just providing the correct signal to the truck, should be fine. I'm gonna try and see
Old 06-03-2023, 12:38 PM
  #199
I gotta rethink my injector 1 and TB signal sources, i got the truck started and it was in reduced power mode after the 3 start and its throwing a P0200 code and TB low circuit A or something. any suggestions?
Old 06-03-2023, 02:20 PM
  #200
Alanis001's Avatar
I hooked it up the yellow and black wire to the tac module pin 1 green wire for tps
Quick Reply: Using a TCM-2650
