V6 to V8 Swap: Wont Start
Old 12-15-2006 | 05:10 PM
  #21
Dirty 30's Avatar
LS1Tech Whore
Originally Posted by thunder550
You sure you got the injectors all plugged in the right order? Check your spark again like I said above, ground the plug electrode to a clean metal surface.
Yes the injectors and coil packs are all connected right. I still need to try what you said though.
Old 12-15-2006 | 05:11 PM
  #22
thunder550's Avatar
High on diesel fumes
Originally Posted by Dirty 30
Im pissed off and sad cause i worked so hard installing it then this happens
Keep your head up, you'll get it figured out. This **** is frustrating and takes time, don't let yourself get overwhelmed.
Old 12-15-2006 | 05:12 PM
  #23
Dirty 30's Avatar
LS1Tech Whore
Originally Posted by gao8302
did you put the engine together? And are you sure that every thing to put together right?
Yes and Yes.
Old 12-15-2006 | 05:13 PM
  #24
Dirty 30's Avatar
LS1Tech Whore
Thanks everyone, i just want it to fire up even if it blows up 10 minutes later, i just want to know it works
Old 12-16-2006 | 11:31 AM
  #25
Dirty 30's Avatar
LS1Tech Whore
I re-learned the VATS last night again and security light went away but still did not start. As of right now the security is still off but the spark plugs arent getting any spark. We tested it just like thunder 550 said.
I hooked it up to the scanner and it does read RPM's, injector pulse, fuel, timing advance, and everything but spark.
Im gonna try to swap the coil packs see what that does for me. I really doubt its the coil packs though.
Old 12-16-2006 | 08:43 PM
  #26
Congrats on getting it started and running today.
Old 12-16-2006 | 09:55 PM
  #27
thunder550's Avatar
It runs? Sweet!! What was the problem?
Old 12-17-2006 | 01:07 AM
  #28
He ran a ground for the coils...and it started.
Old 12-17-2006 | 01:14 AM
  #29
thunder550's Avatar
?? was there a problem with the stock harness or something?
Old 12-17-2006 | 01:37 AM
  #30
Dirty 30's Avatar
LS1Tech Whore
WOOT IM SO FREAKIN RELEIVED! I think there is a ground wire broken inside the wiring harness.
