Valve cover vent for PCV
Trying to figure out what to do for my valve cover vent! I found this http://www.metcomotorsports.com/prod...BR0003&cat=113 but i wonder how bad the oil smell would be??? i really dont want to drill any holes into the intake, and i cant do anything with the throttle body! Ohh for those who dont know this is for a Fast 90mm intake and LS2 Throttlebody
Resident Retard
What I decided to run with my LS6 intake was the following... Because my Electric TB does not have the vent tube like the cable type, and I am not drilling on the intake..
Passenger VC vent line goes to the intake tube, using these
http://www.nitrousoutlet.com/catalog...roduct_id=2719
Then
This 1/8 NPT to 3/8 barb fitting screws into the above....
http://store.summitracing.com/partde...0&autoview=sku
The PCV line will go into a CCA catch can....
Then into the intake...
If you going to run a MAF you can not have any breathers in the system, cause you will suck in Un-Metered air threw it....
Then
lucas287
31
01-12-2021 06:18 AM
Pontiac Derek
09-19-2015 01:49 PM
SWINGRRRR
09-03-2015 07:49 PM
