Vibration at idle in gear
Old 12-07-2013 | 01:12 PM
MWood's Avatar
Default Vibration at idle in gear
As the title states, I have a vibration at idle (600 rpm) while in gear. It does not vibrate in Park or Neutral. It also does not vibrate once I let off the brake. I just bought the truck.
Specs
2004, Chevy Silverado 1500, LS, LM7 5.3, 4L60e, 3.42 rear gear
98,200 miles
Thanks for any help in advance.
Old 12-07-2013 | 02:13 PM
AUTOT3K's Avatar
do the RPM's stay steady when its doing it?
I'd check the mounts, engine and trans.
have it in park, put the e brake on, start the vehicle and have someone else hold the brakes and go from reverse to drive and back to reverse a few times, watch and see if its rocking a lot
Old 12-07-2013 | 03:07 PM
MWood's Avatar
Yes the RPMs remain steady. I don't think it's an engine related issue. My thoughts are either the mechanical fan, or as you stated the engine/transmission mounts.
Also, I should have said it in the first post, but it is 2wd. Also, when I come to a stop there is a "thud". Makes me think even more that is is a mount issue.
Old 06-15-2015 | 11:41 PM
I know this is a long shot. My truck does the exact same thing. My vibration only starts once the truck is warm. I also notice that it is worse if I am stopped on a hill. Did you ever find out what the problem was? My truck is a stock 4.8L 2wd automatic crew cab with 88k. My vibrations started at about 80k.
chopperloco
07-10-2016 11:45 PM
vipergtrdj
08-06-2015 11:19 PM
V-seriesTech
07-28-2015 01:31 PM
GMCtrk
07-17-2015 07:39 PM
Breitling
07-06-2015 07:39 PM
