vortec heads
vortec heads
i have been trying to find heads for my vortec 350 and the only ones i can come up with is eldelbrock e-tecs. has some one ran those heads or now any thing about them.
thanks
jamie
thanks
jamie
Why not just port the heads that are on there?? you can make tons of power off of porting the stock heads... There are aluminum fastburns out there but for the price you could get the etec 200's for the same and they have bigger ports... I would just port the stock heads though, you can make as much power if not more than the etec's by porting the stockers
I agree, the stock fastburns were very good. There are tons of engine builders that can get excellent results with them.
If your handle is accurate, you may want to look at the Edlebrock's. Turbos love flow and you would see awesome results using the e-techs, and the aluminum would help reduce detonation.
i had ported heads on it but i just sold them to get aluminum just to help with the detonation. the guy at eldelbrock said if i put 208 they will flow alot better than the 202 will. does any one know if their is another company that builds them in aluminum for the vortec. i have looked at world,afr,pro action and a few more on the internet. but no one makes them to fit the vortec it kind of sucks.
thanks
jamie
thanks
jamie
I if you go for the E-Tech you probably better off with the 170 over the 200 they have better port velocity and make more low end torque. Evey test I've seen the 170 out power the 200 until the very top of the rpm range and is unusable.
i have the eldelbrock fuel injection for the vortec style heads and will cost to much to go with the old style heads. it is actually in my car that is turbocharged and has alot of bottom end so probly go with the 200. in the truck section is the only place i could find someone that knew about those heads thanks for all the help and info
thanks
jamie
thanks
jamie
silverstreak07
06-28-2016 06:29 PM
gaps
09-02-2015 01:19 PM
sauldgold
07-23-2015 02:15 PM
