VortecMAX/LQ9 swap help, lots of questions.
Ok guys, I got a Lq9 for 700 after negotiation plus taxes Plus 3 month warrany. Motor has 75k miles on it. I want to do as little as possible to get it in my truck and runing well, and have the dependability that I require. I need to keep cost to the minimum, I plan to do the swap myself. I know that I need it tuned for the 6.0. I have a local tuner. I plan to reuse the 6.0 injectors off the melted intake manifold. They look good, but Ill inspect closer.
The 1st thing I notice is that its DBW, but I know my intake and t-body will swap over. Cause it needs it literaly!
2nd thing I noticed is that the exhaust manifolds are slight different my 5.3 has a egr tube on the passenger side. The lq9 manifolds has none.
3rd I notice on the driver side of my lq9 the front and rear bolt on manifold is broke in the head (2), but the manifolds are still held tight by the other bolts. (do I worry about this, or will it be quite as I plan to leave them) My stock 5.3 even has 1 broken bolt as well. This is no where near the questions I have to ask yet, as I do this swap.
The engine is out of a 2004 Escalade 4x4, its going into my 2001 Tahoe 2wd. Here is my progress:
![](http://i756.photobucket.com/albums/xx206/sleeperlqx/1d0db275.jpg)
![](http://i756.photobucket.com/albums/xx206/sleeperlqx/10fbf988.jpg)
Broke off the melted plastic off this sucker.
![](http://i756.photobucket.com/albums/xx206/sleeperlqx/4d87e1bd.jpg)
With the crust ripped off, I can access the intake manifold bolts
![](https://i756.photobucket.com/albums/xx206/sleeperlqx/dac15e0b.jpg)
Took the intake off, few mins ago engine looks awesome. Now I have to tape off, vacuum, clean, then vacuum some more.
This is left from the melted intake, the bottom of the intake looks great, so do the injector nozzeles. Ill pull the injectors out in a few.
![](http://i756.photobucket.com/albums/xx206/sleeperlqx/40b371cc.jpg)
Now I got to tape up the intake ports on the heads, and vaccum the hell out of the block, then untape the ports, and vaccum inside the chamber for anything. Then tape it up tight.
![](http://i756.photobucket.com/albums/xx206/sleeperlqx/a9f8f61e.jpg)
![](http://i756.photobucket.com/albums/xx206/sleeperlqx/c8f3c547.jpg)
What a steal for the price, once I got the intake off it..
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
Great info, as I was not sure. So I should use my same intake, tbody and injectors. Then have my tuner dial it in?
Lol, thats the difference between you and me. Why spend 1grand on a cam swap, cam, lifter, pushrods, springs? When I can go from 285hp 5.3 to a 355hp (lq9 engine dyno) for 700$. Was more my train of thought, than doing a cam swap for a lot less gain. Now once the LQ9 is running well, then Ill do every bolt on to it for even more gains. Other Lq9s in my area are 1400$ starting with similar and more mileage than this. This was a no brainier.
Just re-use everything off of your 5.3. Intake fuel rails injectors and throttle body are all the same in those year models between the 5.3 and 6.0. The injectors are the same between your 5.3 and the 6.0 in that application. I would not trust salvage yard injectors after a fire that is an accident looking for a place to happen. It's straight forward use everything off your truck reflash the pcm for a 6.0 and everything will work fine. Done it before there should not be any snags that you will run into.
