Water drip when you dont use the AC?
I noticed today that water was dripping from the AC drain tube. I never turned on the AC. I did use the heat. I also notice that when I turn the heat on the engine bogs a tad as if I kicked on the AC compressor and I even hear the "Click" like the compressor kicked on. Is this normal? The AC light was not on and it was blowing nice and hot. Does the heated air run through the dryer?
for some reason, my compressor always runs when i have it on recirculate. regardless of whether or not the AC button is pushed. even running heat, the compressor can pull moisture out of the air.
My light still works. I checked. Sometimes it gives me 3 or 4 flashes and then goes out again. But usually it work perfect, light on, cold air. It just seems as if the compressor is kicking on even when I have the heat on. I might pull the belt and see what happens.
PT's Slowest Truck
Originally Posted by Kingpimp
I remember reading something that said your a/c is turned on when you select defrost, since it dries out the air.
1SlowHoe, does your ride have Auto temp control? If so, the AC compressor is probably coming on, even if you have the heat on and defroster off, which would be normal operation for that system...pretty sure it uses a thermistor in the cabin to sense the temp and control it accordingly.
PT's Slowest Truck
Originally Posted by SnakeOiler
recirculate will turn on the compressor.
