Water pump Install??
Well, I think that my water pump is taking a crap on me. I have a 2005 CC Z-71 with a 5.3. I have coolant leaking from somehere underneath and best I can tell it is coming from the water pump. I am contemplating changing it myself, but I dont have alot time in the next week to do it. So, should I take it in to a shop, or attempt myself? It looks like you have to take all the brackets of the engine to get to it.
The House is Rockin'
i helped my dad do his in a couple of hours, not that bad. you gotta take off the fan clutch, and serpentine belt, and a couple other things. pretty easy to do...
by the way its probably the gaskets that are leaking, pump is probably still alright.
I cant really tell.The truck has 86,000 on the clock. If I pull it apart, its getting a new gm pump. I have factory electric fans also. I dont want to dive off in it, unless I know I can finish it before I go back to work on friday. Thanks for the info.
o ok, well once you remove the intake tube, and take off the serpentine belt and hoses, if i remeber right theres like 4/5 bolts holding the pump on.
If your asking how hard it is to change a water pump on a ls engine.. Id bring it to the shop...
Takes longer to drain the coolant out the drain plug,then it takes change pump. 6 bolts & four hose clamps
yea i just pull the pump off and let the coolant come out there..
remove the intake tube, belt, and 3 bolts on each side of the pump, dont forget new gaskets.
clean the block and work backwards
its stupid simple
its stupid simple
It's not hard at all. Once you get the CAI off, predetermine where you can put the coolant hoses so you loose the least amount of fluid. That's the catch, where's the fluid going to go when you pull the hoses. If your going to pull the pump, some good preventative maintenance would be to replace the stat
