wats ur tranny temp run??
12 Second Club
My stock 4l80 will run at 110-130 under normal driving, 150-160 when I beat on it. This tranny has about 10K miles on it using the factory cooler.
My original tranny ran similar temps until the dealer replaced my cooler lines, then it ran so hot:
It lasted about three days.
11 Second Hall Moniter
AndysC3, maybe your cluster stepper motor is bad? I've seen a few that are off a bit, but the majority of clusters with trans temp gauges are pretty close.
It should also be said that it seems to be common that 80e's run hotter than 60/65e's by about 30-40 degrees, from what I've noticed. Even with 40K coolers.
